Results 331 to 360 of 716
https://www.ruutu.fi/video/4650176
AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEMQYsV XY30og/fQTGQ6g655I49yVmwY=
[Attachment 85512 - Click to enlarge]
[Attachment 85513 - Click to enlarge]
cant find the donwalod link -
Downloading from Eurovision - it gets downloaded but decryption fails. I wonder why. Just changed format to mp4 :
H "Referer: https://eurovisionsport.com/" --key 7bd941182e4e4f129298a2e7a30c508b:403158e8094b824d0 12db7398f46768e --use-shaka-packager -M format=mp4
https://eurovisionsport.com/mediacard/athletics/EVS_250215_20250215EARoubaix_1
23:29:33.197 WARN : PSSH(WV): CAESEHvZQRguTk8Skpii56MMUIsaBW5hZ3JhIglTcG9ydHNfMD E=
23:29:33.245 WARN : KID: 7bd941182e4e4f129298a2e7a30c508b
23:29:33.248 INFO : Decrypting using MP4DECRYPT...
23:29:33.716 ERROR: Decryption failed
23:29:33.912 INFO : Done
do you have shaka-packager
look fine with me
Code:13:27:12.390 WARN : Type: cenc 13:27:12.392 WARN : PSSH(WV): CAESEHvZQRguTk8Skpii56MMUIsaBW5hZ3JhIglTcG9ydHNfMDE= 13:27:12.392 WARN : KID: 7bd941182e4e4f129298a2e7a30c508b 13:27:12.393 INFO : Decrypting using SHAKA_PACKAGER... 13:27:15.847 WARN : sport.mp4 13:27:15.858 WARN : sport.eng.m4a 13:27:15.867 WARN : Muxing to sport.MUX.mp4 13:27:23.103 WARN : Cleaning files... 13:27:23.559 WARN : Rename to sport.mp4 13:27:23.641 INFO : Done
Yes. The latest version. Initially, it told me it was incompatible : An error occurred trying to start process 'C:\Users\***\Documents\Video Downloading\widefrog_v2_1_0_windows\shaka-packager.exe' with working directory 'C:\Users\*****\Documents\Video Downloading\widefrog_v2_1_0_windows'. The specified executable is not a valid application for this OS platform.
Then i downloaded the latest version. After that it gave me this error with the decryption.
Edit : I got this shaka-packager for windows 64 bit : packager-osx-x64
Maybe I need this one : packager-win-x64.exe
Let me try.Last edited by EV Downloads; 16th Feb 2025 at 10:01.
the 2nd season can download by m3u8 ,but the first season, has ecryptd, when i use andriod, just avallibale in the ruutu app, on pc i am use edge , it can be play ,but get the woronng key something like that N_m3u8DL-RE "https://nelonenmedia-vod-d.nm-stream.nelonenmedia.fi/out/v1/a02eb92099b04441865950fbc8f52bb2/411d083f3dfb484e9637f5d4ea511368/5eef750a9acb4add9f9470fbd91a1d0b/index.mpd" -M format=mp4 --key e15f3e66571b3b835742db1b30ee9c37:66e45d02f36e2bb30 a3eaea929362661 --key 3f7a5b508f6c08d0dab98745d4b48649:c3019b687db2c890e fdf1100ade4c7a6 --key 2ae7a25a3c1fecffbd17ad1f5f8a1295:4e79f535973c7badd 86c9cf14b14ab12 --key 90ef798addcee43dacee078d3756e5fa:736843caf7bda469a 929020920de6986 -sv best -sa best --save-name "FreeWheel Topics API" --save-dir "C:\360Downloads"
but i cant play on chrom or firefox . -
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
I have installed the "WidevineProxy2" extension and when I go to play content from Amazon, Vodafone, etc... I get errors and they do not play. What happens? What am I doing wrong?
I leave you a screenshot:
[Attachment 85565 - Click to enlarge] -
Hello mates, first of all. Than you so much for this big addon, it works fine!
Only a question
On adultswim web im gettin trouble with the synthax, because it download the ad, im try to get the .m3u8 later, but told me "I am not authorized"
[Attachment 85596 - Click to enlarge] -
Adult Swim is a bit of a pain. I was trying to manually download from them in the past and start this thread: https://forum.videohelp.com/threads/415657-Adult-Swim-Warner
It ended up being so much work, I gave up. I'm not sure this addon can manage the issues. -
HTML Code:
12a558d2a5944d7b3c22257c7f068d6e:7d8514e4383d40ecfbd00e4f0f45804e 9be4c160976044ea0971c90ae9e3f21d:e877deb06e6d4f0a1134b401c90c2e3f 4629dbfa07248c375eeef81009c9c3a7:bb779f0e002bda4651d6d342954f0e9f 72ff146ec3d74c563182b7d53bb688cc:a594ad08269e8f00ba7f934b1361bace
HTML Code:https://nelonenmedia-vod-d.nm-stream.nelonenmedia.fi/out/v1/056b6a17ccbb4fc9bd90d725c0cc41f1/411d083f3dfb484e9637f5d4ea511368/5eef750a9acb4add9f9470fbd91a1d0b/index.mpd
Just want to thank you for such nice extension!
Before that I've used WidevineFetch for key searching + mpd link. This one is ALL-IN-ONE!
Now, one small question.....I'm using CMD function, and I'm just wondering if there is function
to skip "quality video" question/list? i.e. when i paste CMD function in CMD Prompt and press enter
then I got list of all resolutions and highest is already selected so I have to press enter to start download.
So, is there some function which I can add to that CMD function from extension to bypass resolution
list? To automatically download in highest resolution?
Thanks!!
edit: found solution (if anyone need) --select-video best (it comes after mpd link in cmd function)
but you have to add also: --select-audio all (if you don't add this one, video will be downloaded
automatic but without sound). Sorry for inconvenience.
Is it possible to add a key merging feature based on manifest? For example if a site uses 2 different license requests for video/audio, and those 2 keys are for the same manifest (identical url), you could generate only 1 row instead of 2 key rows. Because if there's 2 rows then you have to take the keys and add them to the other command.
Example (swiss IP)
https://www.rts.ch/play/tv/doc-portrait/video/les-dents-de-la-mer-un-succes-monstre?ur...video:15483865--[----->+<]>.++++++++++++.---.--------.
On TubiTV I ran across when it comes to "Tremors: The Series" when I launch the browser WidevineProxy2 can get the Nm3U8DL-RE command for the episode I selected and I can download the video. When it has done that when I click on the next episode WidevineProxy2 doesn't sense it no matter how how often I click on refresh. The only thing that works is closing the browser and coming back to the website and then clicking on the episode than WidevineProxy2 has the Nm3U8DL-RE command. Thankfully thus far this is a rare thing and this particular series with another streaming download program that program says no files exist to download.
My friend has a problem with the Widevineproxy extension - the cmd section is not displayed for him - only the key and pssh are displayed.
My friend checked in different browsers.
It looks like this:
[Attachment 85825 - Click to enlarge]
(It displays for me, but not for my friend) -
your using old version, updated it to get manifest and cmd
[Attachment 85827 - Click to enlarge] -
hi everybody!
But the RSI is available?
with all video the externsion give no data and remain blank.
example: https://www.rsi.ch/play/tv/squadra-speciale-invisibili/video/milan-episodio-1?urn=urn:...:video:2213486 -
Blank cause no DRM. You can use stream detector for that.
It works well on my Windows 10, but I keep getting an error on my new Windows 11.
I have the latest shaka-packager.
[Attachment 85898 - Click to enlarge]
I get the download cmd, and run it on my windows 10 - the shaka-packager has no issues decrypting.
But on my new windows 11, it keeps getting an error.
Shaka-packager is in my system environment variables. Latest N_m3u8DL-RE.
Is windows 11 the issue? -
[Release] Widevine L3 Guesser Extension-Works in 2024 Firefox/Chrome All OS
By FoxRefire in forum Video Streaming DownloadingReplies: 795Last Post: 15th Oct 2025, 11:19 -
[Release] WidevineFetch - Keys from just the License URL; Any Lic. Wrapping
By larley in forum Video Streaming DownloadingReplies: 262Last Post: 4th Sep 2025, 04:00 -
MY5:- HMAC and AES: NO BROWSER REQUIRED Stand-alone script.
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 10Last Post: 22nd May 2024, 10:18 -
Lic with jsondata
By sangoku in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2022, 15:02 -
help decrypting drm dash hmac
By filipino in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2021, 06:07
